Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 2
Using the flat end of heavy-duty spudger, carefully lift the black tab that holds the charger port cable in place. Slide the cable out.
  • Using the flat end of heavy-duty spudger, carefully lift the black tab that holds the charger port cable in place.
  • Slide the cable out.
  • There is a small strip of adhesive holding the charger port cable to the battery. You may need to slide the heavy-duty spudger between the cable and the battery to slide the cable out.
Insertar traducción aquí
