Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 6
Paso 6
Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case. Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
  • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
  • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
  • Gently lift off the top case.
Insertar traducción aquí
