Saltar al contenido principal
Inglés
Español
Paso 6
On the negative terminal, locate the nut on the side facing upwards. Using the wrench, rotate the nut counterclockwise and remove it from the bolt. Using the wrench, rotate the nut counterclockwise and remove it from the bolt.
  • On the negative terminal, locate the nut on the side facing upwards.
  • Using the wrench, rotate the nut counterclockwise and remove it from the bolt.
Insertar traducción aquí
