Saltar al contenido principal
Inglés
Español
Paso 4
On the positive terminal, locate the nut along the side. Using the wrench, rotate the nut counterclockwise.
  • On the positive terminal, locate the nut along the side.
  • Using the wrench, rotate the nut counterclockwise.
  • You do not need to fully loosen the nut off the bolt, but just enough for the terminal to be easily removed from the node.
Insertar traducción aquí
