Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Paso 3
Always remember to remove the negative terminal first before the positive terminal. This will prevent shorting to the ground and possibly causing shock or a fire. Carefully use a rag to lift up the terminal off of the battery node.
  • Always remember to remove the negative terminal first before the positive terminal. This will prevent shorting to the ground and possibly causing shock or a fire.
  • Carefully use a rag to lift up the terminal off of the battery node.
  • Be cautious when handling battery corrosion, as it can irritate the skin and is harmful if it comes in contact with your eyes.
  • Place the terminal on a rag or towel and make sure it doesn't come in contact with the battery node.
Insertar traducción aquí
