Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Use the plastic opening tool to remove both components of the front panel. This includes the black part on the outside of the front panel and the main silver panel. Once every screw and panel is removed, you can replace the backplate to make your camera weatherproof again. Once every screw and panel is removed, you can replace the backplate to make your camera weatherproof again.
Front Panel
  • Use the plastic opening tool to remove both components of the front panel. This includes the black part on the outside of the front panel and the main silver panel.
  • Once every screw and panel is removed, you can replace the backplate to make your camera weatherproof again.
Insertar traducción aquí
