Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Find the plastic clips on the side of the battery slot. Using a Plastic Opening Tool, release the clips by pulling up inside the crevasse in the plastic walls and separate the two pieces. For this step you will want to use two tools. One to pull up and the other to hold the gap open.
Remove Inner Back Panel
  • Find the plastic clips on the side of the battery slot.
  • Using a Plastic Opening Tool, release the clips by pulling up inside the crevasse in the plastic walls and separate the two pieces.
  • For this step you will want to use two tools. One to pull up and the other to hold the gap open.
Insertar traducción aquí
