Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 19 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Carefully lift the lower casing from its bottom edge. The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
  • Carefully lift the lower casing from its bottom edge.
  • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
  • Pry the volume and SD board cable up from its socket on the motherboard with the flat edge of a screwdriver.
  • once the cable, highlighted in the orange box, is completely removed then you may take off the entire outer casing.
Insertar traducción aquí
