Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 6
Paso 6
Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case. Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
  • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
  • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
  • Gently lift off the top case.
Insertar traducción aquí
