Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them Use your Phillips head #0 to remove the one - 7mm bottom center screw Use your Phillips head #2 to remove the two - 8mm screws by the handle
  • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
  • Use your Phillips head #0 to remove the one - 7mm bottom center screw
  • Use your Phillips head #2 to remove the two - 8mm screws by the handle
  • Push down the two release points to pull the plastic piece up
  • Pull the plastic piece up
Insertar traducción aquí
