Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 6
Detach the ribbon cables by opening the specified latches. Turn the laptop upside down and remove the M2.5x8mm screw with Phillips #0 screwdriver. Turn the laptop on its side and pry the bottom from the top.
Removal of Palm Rest
  • Detach the ribbon cables by opening the specified latches.
  • Turn the laptop upside down and remove the M2.5x8mm screw with Phillips #0 screwdriver.
  • Turn the laptop on its side and pry the bottom from the top.
  • Only partially remove the palm rest; there is still a ribbon cable attached underneath it.
  • Remove the ribbon cable by opening its respective latch.
Insertar traducción aquí
