Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Gently pull up on the speaker cable connector to disconnect it from the front panel board. Be careful to pull up on the cable's connector and not the connector on the board. It's pretty flimsy and you might accidentally pull it off the board entirely. Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
  • Gently pull up on the speaker cable connector to disconnect it from the front panel board.
  • Be careful to pull up on the cable's connector and not the connector on the board. It's pretty flimsy and you might accidentally pull it off the board entirely.
  • Use the flat end of a spudger to disconnect the antenna cable from the front panel board.
Tire suavemente del conector del cable del altavoz para desconectarlo de la placa del panel frontal.
Tenga cuidado de tirar del conector del cable y no del conector de la placa. Es bastante endeble y es posible que accidentalmente lo saques del tablero por completo.
Use el extremo plano de un spudger para desconectar el cable de antena de la placa del panel frontal.
