Saltar al contenido principal
Inglés
Español
Paso 7
Use a torque wrench to tighten the spark plug to a spec of 156 in-lbs (13 ft-lbs).
  • Use a torque wrench to tighten the spark plug to a spec of 156 in-lbs (13 ft-lbs).
  • If a torque wrench is unavailable, tighten the spark plugs by hand, and finish with a 1/4-1/2 turn using a socket wrench until snug.
  • Do not over-tighten the spark plugs, as the threads may strip out of the soft aluminum cylinder head.
Use una llave dinamométrica para ajustar la bujía a una especificación de 156 in-lbs.
No apriete demasiado las bujías, ya que las roscas pueden desprenderse de la culata de aluminio blando.
[* black] Use a torque wrench to tighten the spark plug to a spec of 156 in-lbsin-lbs (13 ft-lbs).
[* icon_note] If a torque wrench is unavailable, tighten the spark plugs by hand, and finish with a 1/4-1/2 turn using a socket wrench until snug
[* icon_caution] Do not over-tighten the spark plugs, as the threads may strip out of the soft aluminum cylinder head.
