Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Holandés
Traduciendo paso 46
Paso 46
Lift the logic board by the camera end and gently pull the Lightning connector housing out of the rear case. Remove the logic board from the iPad. If there is any resistance from the Lighting port cable stop pulling to avoid ripping the cable. Slide the opening pick under the length of the cable again to fully free it from the rear case.
  • Lift the logic board by the camera end and gently pull the Lightning connector housing out of the rear case.
  • Remove the logic board from the iPad.
  • If there is any resistance from the Lighting port cable stop pulling to avoid ripping the cable. Slide the opening pick under the length of the cable again to fully free it from the rear case.
Insertar traducción aquí
