Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Holandés
Paso 42
Reinsert the opening pick under the Lightning connector ribbon cable from the case-side edge. Slide the pick along the Lightning connector ribbon cable and under the logic board. Move slowly and carefully. If the opening pick does not slide easily, apply more heat and try again. If you use excessive force, you will likely slip and sever the Lightning connector cable.
  • Reinsert the opening pick under the Lightning connector ribbon cable from the case-side edge.
  • Slide the pick along the Lightning connector ribbon cable and under the logic board.
  • Move slowly and carefully. If the opening pick does not slide easily, apply more heat and try again. If you use excessive force, you will likely slip and sever the Lightning connector cable.
  • Leave the pick under the Lightning connector cable to keep the adhesive separated.
Insertar traducción aquí
