Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 12 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Pull the wide tape toward the battery, applying constant force to peel it from the antenna cable lodged between it and the speaker. Insert a plastic opening tool into the gap between the wide tape and the antenna cable, to break the adhesive connecting the two. Slide the plastic opening tool along the length of the antenna cable to completely separate it from the piece of tape.
  • Pull the wide tape toward the battery, applying constant force to peel it from the antenna cable lodged between it and the speaker.
  • Insert a plastic opening tool into the gap between the wide tape and the antenna cable, to break the adhesive connecting the two.
  • Slide the plastic opening tool along the length of the antenna cable to completely separate it from the piece of tape.
Insertar traducción aquí
