Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 12 guías que incluyan este paso.
Inglés
Español
Paso 3
Use the point of a spudger to gently lift the battery connector up off its socket on the logic board. Be very careful to only pry up the battery connector, not the socket itself. If you pry up on the logic board socket, you may break the connector entirely. Make sure to pry up the battery connector before attempting any other repairs inside the device.
  • Use the point of a spudger to gently lift the battery connector up off its socket on the logic board.
  • Be very careful to only pry up the battery connector, not the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
  • Make sure to pry up the battery connector before attempting any other repairs inside the device.
Insertar traducción aquí
