Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Push on the battery housing to separate the midframe from the display assembly. You will have to apply a reasonable amount of pressure to separate the two parts. If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
  • Push on the battery housing to separate the midframe from the display assembly.
  • You will have to apply a reasonable amount of pressure to separate the two parts.
  • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
Insertar traducción aquí
