Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Paso 7
Insert the edge of an opening tool under the steel mid plate near the bottom left corner of the Touch. Slowly pry upward to separate the plate from the adhesive securing it to the plastic inner case. If the plate is still attached to the logic board, re-warm the area to loosen the adhesive, then slowly separate the plate from the logic board using the opening tool.
  • Insert the edge of an opening tool under the steel mid plate near the bottom left corner of the Touch.
  • Slowly pry upward to separate the plate from the adhesive securing it to the plastic inner case.
  • If the plate is still attached to the logic board, re-warm the area to loosen the adhesive, then slowly separate the plate from the logic board using the opening tool.
  • There is a thin, fragile ribbon cable underneath the plate. As you pry the plate up, be very careful not to rip the cable.
  • This cable may stick to the plate and will tear very easily if you're not careful. Work slowly and be careful not to strain the cable.
Insertar traducción aquí
