Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 3
Use an iPod opening tool to gently pry the battery up from the adhesive securing it to the outer case. The adhesive is very strong. Work carefully and slowly, making sure to not slip and break any fragile components.
  • Use an iPod opening tool to gently pry the battery up from the adhesive securing it to the outer case.
  • The adhesive is very strong. Work carefully and slowly, making sure to not slip and break any fragile components.
  • Use your thumb to pull the battery toward the left side of the Nano as you pry the battery's other edge out of the outer case.
Insertar traducción aquí
