Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 48 guías que incluyan este paso.
Inglés
Español
Paso 21
Leave the pick from the last step in place to prevent the adhesive from re-sealing. With a new pick, slice gently over the left-hand antenna, stopping before the home button. Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
  • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
  • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
  • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
  • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
  • Leave the pick in place before moving on.
Insertar traducción aquí
