Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 48 guías que incluyan este paso.
Inglés
Español
Paso 20
Slide the lower left pick to the lower left corner to cut the adhesive on that corner. Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad. There are quite a few things to avoid beneath the lower bezel, so study the third image closely:
  • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
  • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
  • There are quite a few things to avoid beneath the lower bezel, so study the third image closely:
  • Antennas
  • Home button cavity
  • Digitizer cable
  • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
Insertar traducción aquí
