Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 9 guías que incluyan este paso.
Inglés
Español
Paso 8
Now that the top, left, and right edges of the glass are free from the display, slowly lift the top edge of the glass panel and gently rotate it out of the display. If necessary, use the flat end of a spudger to free the bottom edge of the glass display panel from the display assembly.
  • Now that the top, left, and right edges of the glass are free from the display, slowly lift the top edge of the glass panel and gently rotate it out of the display.
  • If necessary, use the flat end of a spudger to free the bottom edge of the glass display panel from the display assembly.
  • Before reassembling, be sure to clean both the inside of the glass display panel and the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is on.
Insertar traducción aquí
