Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 9 guías que incluyan este paso.
Inglés
Español
Paso 4
Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel. Attach a suction cup along the right side of the front glass panel.
  • Use a heat gun to soften the adhesive under the black strip along the right side of the front glass panel.
  • Attach a suction cup along the right side of the front glass panel.
  • Pull up on the glass panel while you use the flat end of a spudger to separate it from the rest of the display assembly.
  • Continue working along the right edge of the front display glass until it is separated from the display.
  • It may be helpful to use a guitar pick or another thin plastic object to keep the upper right corner of the front glass panel from sticking back down to the display assembly.
Insertar traducción aquí
