Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 5
This step is only for glossy display machines. If you have an anti-glare display, skip this step. Remove the two 8 mm Phillips screws securing the camera cable retainer to the upper case.
  • This step is only for glossy display machines. If you have an anti-glare display, skip this step.
  • Remove the two 8 mm Phillips screws securing the camera cable retainer to the upper case.
  • One of the screws may remain captive in the camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
  • Lift the camera cable retainer out of the upper case.
Insertar traducción aquí
