Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 6
Paso 6
Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD. Pull the display data cable straight away from its socket on the LCD.
  • Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD.
  • Pull the display data cable straight away from its socket on the LCD.
  • Lift the LCD out of the display assembly and set it aside.
  • If you are replacing the LVDS/display data cable, simply de-route it from its slot cut into the display casing.
Insertar traducción aquí
