Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 10
In order to remove the upper LCD and the cameras from the front bezel, it is helpful to coil the ribbon cables together. Carefully coil the two ribbon cables together, so that the connectors are on the inside of the spool.
  • In order to remove the upper LCD and the cameras from the front bezel, it is helpful to coil the ribbon cables together.
  • Carefully coil the two ribbon cables together, so that the connectors are on the inside of the spool.
  • Wrap the ribbon cables tightly, but not too tight, as bending the connectors will render them inoperable.
Insertar traducción aquí
