Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 8
Lift the left side of the front bezel away from the upper case. Do not lift too far, or else the hinge pin will break. Only lift enough to clear the LED compartment, about 1".
  • Lift the left side of the front bezel away from the upper case.
  • Do not lift too far, or else the hinge pin will break. Only lift enough to clear the LED compartment, about 1".
  • Pull the front bezel to the left, separating the front bezel from the upper case.
  • Do not attempt to fully separate the two halves yet. There are still ribbon cables running through the upper case.
Insertar traducción aquí
