Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 7
In the following steps, you will be using a spudger to remove the hinge pin from the left side of the DSi XL. Place the tip of a spudger in the LED diffuser compartment, on the face of the clutch hinge. Push the clutch hinge to the left.
  • In the following steps, you will be using a spudger to remove the hinge pin from the left side of the DSi XL.
  • Place the tip of a spudger in the LED diffuser compartment, on the face of the clutch hinge.
  • Push the clutch hinge to the left.
  • Some force will be required. You will hear an audible "pop" when the clutch has cleared the lower case. It will move about 0.25".
Insertar traducción aquí
