Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 4
This step is only required if you have an anti-glare display. Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
  • This step is only required if you have an anti-glare display.
  • Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
  • One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
  • Lift the Bluetooth board/cable retainer assembly out of the upper case.
Insertar traducción aquí
