Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Pull the Wi-Fi antenna cable through the right hinge connecting the front bezel and upper case. Use the pointed end of a spudger to guide the connector at the end of the Wi-Fi antenna cable through the hinge. To replace the antenna, use a pair of tweezers to guide the connector through the hinge.
  • Pull the Wi-Fi antenna cable through the right hinge connecting the front bezel and upper case.
  • Use the pointed end of a spudger to guide the connector at the end of the Wi-Fi antenna cable through the hinge.
  • To replace the antenna, use a pair of tweezers to guide the connector through the hinge.
Insertar traducción aquí
