Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 2
Using the flat end of a spudger, remove the adhesive securing the volume control switch ribbon cable to the back of the battery compartment. Using the flat of a spudger, pry the volume control switch straight up out of the lower case. Remove the volume control switch from the DSi XL.
  • Using the flat end of a spudger, remove the adhesive securing the volume control switch ribbon cable to the back of the battery compartment.
  • Using the flat of a spudger, pry the volume control switch straight up out of the lower case.
  • Remove the volume control switch from the DSi XL.
Insertar traducción aquí
