Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 2
Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad to separate the adhesive securing the battery in place. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals. Flip the iPad back over and insert a plastic card under the battery cell nearest the logic board and right speaker.
  • Throughout the following procedure, you'll be sliding thin plastic cards between the battery and rear case of the iPad to separate the adhesive securing the battery in place. Be careful to keep the cards as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
  • Flip the iPad back over and insert a plastic card under the battery cell nearest the logic board and right speaker.
  • If you encounter significant resistance, re-heat the iOpener and repeat the previous step to give the adhesive more time to soften.
Insertar traducción aquí
