Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 15
After removing a loop of copper tape around the digitizer connector, the display assembly can finally be separated from the logic board. A copper shield fastened to the back of the battery can also be removed at this point.
  • After removing a loop of copper tape around the digitizer connector, the display assembly can finally be separated from the logic board.
  • A copper shield fastened to the back of the battery can also be removed at this point.
  • Presumably, the rear case is thin enough to warrant a copper shield for either heat dispersion or EMI protection, or both.
Insertar traducción aquí
