Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 9 guías que incluyen este paso.
Inglés
Holandés
Paso 3
Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly. Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display. Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
  • Gently lift the corner of the display glass enough to insert a spudger between it and the display assembly.
  • Use the flat end of a spudger to gently pry up the adhesive securing the front glass to the display.
  • Pry up the glass panel a few inches away from the upper right corner along the top and right edges of the display.
Insertar traducción aquí
