Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Insert the tip of a small flathead screwdriver between the X clamp and its retaining post on the heat sink. Pry the X clamp away from its retaining post until it is lifted above the small groove cut into the retaining post.
  • Insert the tip of a small flathead screwdriver between the X clamp and its retaining post on the heat sink.
  • Pry the X clamp away from its retaining post until it is lifted above the small groove cut into the retaining post.
  • If necessary, insert your screwdriver parallel to the motherboard between the X clamp and its retaining post. Twist the screwdriver to fully release the X clamp from its retaining post.
  • Repeat this process for all four corners of the X clamp.
  • When removing the last corner of the X clamp and holding the motherboard upside down, be sure to catch the CPU heat sink to avoid damage from it falling.
  • Remove the CPU heat sink from the motherboard.
Insertar traducción aquí
