Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Paso 7
Use the edge of your small flathead screwdriver or another thin and sharp object to carefully pull up a corner of the blue or white plastic sheet covering the adhesive on the bottom of both heat sinks. Be careful not to wrinkle or peel up the adhesive in the process.
  • Use the edge of your small flathead screwdriver or another thin and sharp object to carefully pull up a corner of the blue or white plastic sheet covering the adhesive on the bottom of both heat sinks.
  • Be careful not to wrinkle or peel up the adhesive in the process.
  • Peel the protective sheets off the adhesive on both heat sinks.
Insertar traducción aquí
