Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Paso 6
This step is performed with the motherboard out of the chassis. Insert a machine screw through each of the four holes around the CPU heat sink, with their heads on the back side of the board. While holding the head of the screw, place a nylon washer then a metal washer over the threads.
  • This step is performed with the motherboard out of the chassis.
  • Insert a machine screw through each of the four holes around the CPU heat sink, with their heads on the back side of the board.
  • While holding the head of the screw, place a nylon washer then a metal washer over the threads.
  • The order of the washers is important. Do not put the metal washer on first.
  • When attaching the CPU heat sink, be sure the fins are aligned with the air flow from the fans (as seen in the third picture). Having the flat side of the fins perpendicular to the air flow will cause your Xbox 360 to overheat.
  • Using the large flathead screwdriver bit, tighten the screws into the CPU heat sink. First lightly tighten the four screws in an X-shaped pattern as seen in the second picture, then follow the same X-shaped sequence to really torque the screws down.
  • Don't be afraid of over-tightening the screws - the pressure between the heat sinks and processors caused by sufficiently torqued screws is needed to squeeze the processors back against the board.
  • Repeat the same process to attach your GPU heat sink.
Insertar traducción aquí
