Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 3
To reinstall the X clamp, first start by attaching two corners to the posts on the heat sink.
  • To reinstall the X clamp, first start by attaching two corners to the posts on the heat sink.
  • While holding the third arm of the X clamp down against the post attached to the heat sink, use a small flathead screwdriver to pry the X clamp away from the heat sink post.
  • As you pry, press down on the arm of the X clamp until you "walk" it down into the retaining groove cut into the post attached to the heat sink.
  • Repeat this process for the fourth arm of the X clamp.
Insertar traducción aquí
