Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 13 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Insert the flat edge of a spudger between the faceplate and the outer casing near the power button. Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
  • Insert the flat edge of a spudger between the faceplate and the outer casing near the power button.
  • Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
  • You may also accomplish this task by using the edge of the Xbox 360 opening tool, but it may scratch the plastic case.
  • Alternatively, you can use your hands to carefully pull the faceplate away from the Xbox.
Insertar traducción aquí
