Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 7
Push down on the small tab and pull the connector directly away from its socket to disconnect the power lock switch. Use the same method described above to remove the connector for the tweeter. Press the tab on the bottom of the larger green connector to disconnect the side-view mirror controls.
  • Push down on the small tab and pull the connector directly away from its socket to disconnect the power lock switch.
  • Use the same method described above to remove the connector for the tweeter.
  • Press the tab on the bottom of the larger green connector to disconnect the side-view mirror controls.
Insertar traducción aquí
