Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 5
Using firm pressure, pull the door panel away from the door. Start at the top right, and work down the side, across the bottom, and up the opposite side. Multiple clips hold the door panel in place. the door panel will jerk as each clip is freed from its position. Multiple clips hold the door panel in place. the door panel will jerk as each clip is freed from its position.
  • Using firm pressure, pull the door panel away from the door. Start at the top right, and work down the side, across the bottom, and up the opposite side.
  • Multiple clips hold the door panel in place. the door panel will jerk as each clip is freed from its position.
Insertar traducción aquí
