Saltar al contenido principal
Inglés
Español
Traduciendo paso 6
Paso 6
There are three or five relays on the circuit board.  K6 is an OMRON G2RL-1A-E, 12VDC, and rated to switch 16A at 250 VAC.  K1 and K4 are both OMRON G5LE-1-VD, 12 VDC, and rated to switch 10A at 250 VAC.
Circuit board repair and replacement
  • There are three or five relays on the circuit board. K6 is an OMRON G2RL-1A-E, 12VDC, and rated to switch 16A at 250 VAC. K1 and K4 are both OMRON G5LE-1-VD, 12 VDC, and rated to switch 10A at 250 VAC.
  • K1 controls the door lock solenoid. I found the contacts on it were blackened due to arcing. I didn't bother to find out what the other two relays do, but I cleaned them all anyway. Another repairer says that only K1 & K4 were inspected; K1 had significant contanimation & K4 looked new by comparison. Treated K1 only with all problems resolved!
  • Unsolder one relay at a time from the circuit board, clean or replace it, then solder it back in position.
  • To unsolder a relay, start by heating the solder at one end of the relay, and gently pull the relay's plastic package with a finger on the hand holding the circuit board. Use solder wick to remove excess solder. After making progress at one end, switch to desoldering the contacts at the other end of the relay in the same fashion.
  • To clean a relay, open its plastic case. Blow out the dust and grit. Dress the relay contacts with a small piece of folded-in-half 200-400 grit sandpaper, treated with contact cleaner. Replace the plastic case on the relay.
  • Solder the relay back onto the circuit board, and repeat with the next relay until all relays are cleaned and/or replaced.
Insertar traducción aquí
