Saltar al contenido principal
Inglés
Español
Paso 4
Mark the wires and note how the cables are routed, so you can return them to their original routes after disassembly. Either apply wire labels, or take a fine-tipped permanent marker and as you disconnect each connector mark it with the two letter name of the mating socket, which you will find stamped on the plastic of the control unit's housing.  A flashlight will help reading the letters along the left side of the control unit.
Mark the wires
  • Mark the wires and note how the cables are routed, so you can return them to their original routes after disassembly.
  • Either apply wire labels, or take a fine-tipped permanent marker and as you disconnect each connector mark it with the two letter name of the mating socket, which you will find stamped on the plastic of the control unit's housing. A flashlight will help reading the letters along the left side of the control unit.
Insertar traducción aquí
