Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 7
Only use alcohol as a final option. It may damage the printhead seals! IF USED, FLUSH WITH CLEAN WATER 3 TIMES. Recommended circulation times: Alcohol: 5-10 minutes. Without alcohol: 15 minutes.
Clean the printhead
  • Only use alcohol as a final option. It may damage the printhead seals! IF USED, FLUSH WITH CLEAN WATER 3 TIMES.
  • Recommended circulation times: Alcohol: 5-10 minutes. Without alcohol: 15 minutes.
  • The water will get lighter as the ink breaks down. An ultrasonic cleaner may help with stubborn clogging.
  • Put the printhead in hot water. Let it sit until it is reasonably clean. Change the water as it turns black.
  • Wipe down the printhead contacts and nozzles by hand to ensure these areas are dry.
  • Before reinstalling the printhead, let it air dry for ~3-4 hours. Using a fan may speed this step up.
Insertar traducción aquí
