Saltar al contenido principal
Inglés
Español
Paso 6
Similarly, the lower bezel can be easily pried up from body of the Streak. The capacitive control circuitry is securely attached to the inner face of the lower bezel, so it's highly advised to pry up the bezel from below (as pictured), to make sure the circuit does not receive any damage.
  • Similarly, the lower bezel can be easily pried up from body of the Streak.
  • The capacitive control circuitry is securely attached to the inner face of the lower bezel, so it's highly advised to pry up the bezel from below (as pictured), to make sure the circuit does not receive any damage.
  • Since the connector is inside the device, it's a good idea to leave the bezel attached for now.
  • After a bit of digging, the five T5 Torx screws securing the rear case can be removed.
Insertar traducción aquí
