Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 4
Now, remove the big Phillips screw here (actually, you can loosen it then remove the nut in the other side). Don't be worried if it's a little hard to pull the screw. Now, remove the big Phillips screw here (actually, you can loosen it then remove the nut in the other side). Don't be worried if it's a little hard to pull the screw.
  • Now, remove the big Phillips screw here (actually, you can loosen it then remove the nut in the other side). Don't be worried if it's a little hard to pull the screw.
Insertar traducción aquí
