Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 6
Also you can Factory Reset your device. "This performs a factory reset on your device. Your apps, photos, music and settings will be deleted. After you erase the device, Android Device Manager will not longer work. This reset is permanent. We may not be able to wipe the content of the SD card in your device." "If your device is offline, we will perform the factory reset as soon as it goes online."
  • Also you can Factory Reset your device.
  • "This performs a factory reset on your device. Your apps, photos, music and settings will be deleted. After you erase the device, Android Device Manager will not longer work. This reset is permanent. We may not be able to wipe the content of the SD card in your device."
  • "If your device is offline, we will perform the factory reset as soon as it goes online."
También puedes restablecer tu dispositivo a los valores de fábrica.
"Esto realiza un restablecimiento de fábrica en tu dispositivo. Tus aplicaciones, fotos, música y configuraciones serán eliminadas. Después de borrar el dispositivo, el Administrador de dispositivos Android no funcionará. Este restablecimiento es permanente. Es posible que no podamos borrar el contenido. de la tarjeta SD en su dispositivo ".
"Si tu dispositivo está fuera de línea, realizaremos el restablecimiento de fábrica tan pronto como se conecte".
