Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 7 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 17
Paso 17
Handle the logic board assembly by its edges only. Lift the logic board assembly from the side nearest the optical drive and lift it away from the upper case.
  • Handle the logic board assembly by its edges only.
  • Lift the logic board assembly from the side nearest the optical drive and lift it away from the upper case.
  • Note that you'll be removing the logic board and DC-in board together.
  • Carefully pull the ports and DC-In board away from the side of the upper case and remove the logic board assembly, minding any cables that may get caught.
Insertar traducción aquí
