Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Inglés
Español
Traduciendo paso 7
Paso 7
All the parts disassembled.  The adapter cable will probably come out as it doesn't seem to be attached directly, but removing it would have required bending the metal enclosure and I didn't want to mess with that. I thought it interesting to note that the drive runs at 5V 0.62A when the enclosure states 5V 1A.  I wonder where the other 380mA are going. Also interesting to note: this is a Seagate drive, while the 250GB drive upgrade I mention in the description requires a WD drive.  If I understood correctly, this is because the software to format the drive to be recognized by your 360 is written for the WD firmware.
  • All the parts disassembled. The adapter cable will probably come out as it doesn't seem to be attached directly, but removing it would have required bending the metal enclosure and I didn't want to mess with that.
  • I thought it interesting to note that the drive runs at 5V 0.62A when the enclosure states 5V 1A. I wonder where the other 380mA are going.
  • Also interesting to note: this is a Seagate drive, while the 250GB drive upgrade I mention in the description requires a WD drive. If I understood correctly, this is because the software to format the drive to be recognized by your 360 is written for the WD firmware.
Insertar traducción aquí
